Bombfixer
Jun 16, 2014Explorer
I have an R20 hitch. I have no problem knowing when the pin box is off of the lube plate. I look for a break in the contact point. Not necessarily the daylight that a lot of other hitches use, but just a break in the contact between the two. I also lower the legs to just touch the ground, raise the handle and pull out, then finish lowering legs enough to raise pin box off the lube plate until I see a break in the contact between the two. Disconnect umbilical and drive away.
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
