bbaker2001ExplorerApr 25, 2017rv garage:) we finally got approval to build rv garage and workshop on property contractor asked what I would like on walls. sheetrock or OSB he said he liked osb because I could nail to it. isnt osb sort...Show More
bbaker2001ExplorerApr 26, 2017yes I bet the walls will have to be fire protected didn't think about that. I will check with Klamath Falls. the others might be plywood. I do plan on getting electric and water out there. I only have a 30 amp 5er, but probably run wire for 50, if I can plug my 30 into it.I am on septic, so debating on running sewer line to inside or on outside to dump before I put he 5er away. comments on in or out
