odyknuck
Mar 06, 2020Explorer
Ok so your talking about the bell stop on the end of the screw drive. I looked at that and the shaft is all the way to the end of bracket with a nut on each side. Does not appear to be able to adjust out any father. According to the manual there are two bolts on top of each slider that allows some in/out adjustment. If I adjust those I will need to back the stop bell off to allow the slide to close farther, correct? Thanks for the tip on the rubber wheels. Gota fix that as it is really annoying.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
