jetcare
Sep 18, 2017Explorer
I find the Thetford Aqua Magic Style II to be a very troublesome toilet. I have received dozens of calls with the complaint being the pedal does not return to the full up position and the water continues to run. I have only limited success replacing the water valve. Within a few weeks or months I get called back out to work on it again. My suggestion is to replace this toilet with a Thetford Aqua Magic Style Plus with the center pedal flush and the china bowl. This one is about $75 to $100 more but is a much better toilet. Make sure you have enough room behind the existing toilet because the Thetford Aqua Magic Style Plus takes a little more room. If you can't do this, don't fix the one you have, replace it with a new one.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
