Martyn
Sep 19, 2023Nomad
Campinfan wrote:
I have a Demco but there is no locking plate, it has the silver guide rails on the hitch. I have pulled them off or backed them all the way off....was pretty easy.....hooked up and then pulled out. If I had them off. I stopped, put them on and rehitched. Only took a few minutes. Without the rails in place, the hitch still works, it just does not "autoslide". If I had the rails backed off, I just slid them over once the trailer was straight and then tightened them.
My hitch is a few years old now so the design might be a bit different from the new ones.
Mine is the same as this ^^. I would do exactly the same given the circumstances. Just a few bolts to loosen off/remove and the hitch acts like a regular hitch and doesn't slide.
The only alternative to this is to have a friendly neighbor hitch up to your trailer and pull to a spot where you can hitch up straight.
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
