crcr
Jan 17, 2023Explorer
ZeeLet50 wrote:
To answer the OP's initial question and not off topic like this has gone...the short bed will work with the Anderson hitch. It does require situational awareness as does any hitch. Take it too far and there can be damage. The Anderson pulls fine. Just be aware that any placement of the pin further back of the rear axle will affect the ride somewhat. So that offset ball pushing the pin further back will work but you might get more "chunking" or sag. And that will be with conventional or Anderson hitches. The only difference you can see between the Anderson and conventional setup to the trailer will be a conventional will have a larger contact area with the pin box. I dont see how this stresses the frame more. It could break the pin off of a badly welded pinbox but maybe there is something I am missing or its just CYA of the manufacture. The new Morryde pinboxes are much beefier than the standard pinbox that used to come on the pre 2019 models.
Thanks to the input in this thread, I don't expect to try to / need to use an offset gooseneck ball. It sounds like you have experience with the Andersen hitch, so I have a question, if I might, for you, or anyone else with experience with the Andersen. The ball on top of the Andersen hitch in my truck appears to sit pretty much right over the rear axle.
The Andersen coupler, as you know, is going to offset the kingpin a few inches to the front or rear from the Andersen ball. I understand that pinbox positioning and the front cap of fifth wheel campers vary. My question is, would you suggest I use the Andersen coupler to offset the kingpin to the front or rear of the Andersen ball? This would be a starting position and I would then tow and observe carefully, and if needed, switch the direction of the Andersen coupler.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
