NWKomfort350
Aug 30, 2017Explorer
4x4ord wrote:
You said you run just enough
air pressure to be off your overloads. I didn't think the F250 had overloads? I think you should try dumping the air out of your air bags. I'm guessing your overload springs are banging oon thier supports. My truck rides very similar towing as it does empty.
Some F250's have overloads. Essentially he has an F350 if it has overloads.
I don't use airbags and my truck rides on the overloads.
I consider my combo to ride quite comfortably.
I agree try running with no air in the airbags so the truck will use its suspension the way it was originally setup.
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
