Lantley
May 18, 2024Nomad
I currently Have Harbor freight Portable 5K dual fuel genset. My prior 5'er had a Built in Onan 5500 LP.
Unless you use your genset every trip Go with Lp portable. They don't have the carb and fuel issues that gasoline powered units do. You also don't have to deal with gas cans and spillage
If you plan to use genset5 most every trip a built in is 1000 times more convenient that any portable.
Push button convenience means zero set up. Zero hauling, zero take down. Zero loading and unloading.
Check out RVMP generators if you are interested in a built in alternative to Onan.
At this point I have owned built in and portable. For regular use go built in for occasional use portable is OK but will never be as convenient as built in.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
