Edd505
Sep 19, 2020Explorer
TenOC wrote:
We have just purchased a new-to-us 5th wheel trailer with six-point leveling system. Watching videos on how to use the six-point leveling system it states that there is no longer any need for wood or plastic blocks underneath the wheels to level from side to side.
What is your real-life experience on the need for some type of block under the wheels to aid the six-point leveling system?
Do you carry any blocks with you?
Yes you can do without them, BUT. The shorter the legs extend the less "wobble" you get walking around inside. I had legos left from my prior RV's and use them every time to keep movement down. They cn also be used to change flats, build a ramt with them and pull the good tire up it, now you can change the flat, no jack needed. (I do carry one just in case)
About Fifth Wheel Group
