TenOC's avatar
TenOC
Nomad
Sep 18, 2020
Real-life experience blocks to aid 6-point leveling system
We have just purchased a new-to-us 5th wheel trailer with six-point leveling system. Watching videos on how to use the six-point leveling system it states that there is no longer any need for wood or plastic blocks underneath the wheels to level from side to side.
What is your real-life experience on the need for some type of block under the wheels to aid the six-point leveling system?
Do you carry any blocks with you?
  • We don’t carry additional blocking, nice to have more room in the basement. Initially carried 10x10 pads, but stopped doing that when we put snap-pads on (highly recommended), again nice to have more basement space now and great/quick setup without placing pads.
    We usually stay at state or city parks, very seldom paved, and haven’t had a problem in two years of traveling halftime (30+k miles, throughout NW, SW, Midwest, South and Canada)
  • We still carry the plastic blocks. We have ran into sites sloping so much the blocks helped the jacks from extending so far out or not having enough travel. We have also ran into campgrounds who require something to be placed under the pads.
  • If you camp on paved driveways with no slope, you won't need blocks. But we've needed them on several occasions when parked on dirt, in fields etc. We keep a storage bin full of them in our basement storage. We had a trip this year where we were on a site so unlevel, we ended up with the front jacks nearly retracted all the way, and our rear drive's side needing to extend all the way, plus some blocks under it.
  • joelc's avatar
    joelc
    Explorer III
    Yes. I have 6x6 blocks. Sometimes the ground is so far off the levers can't do their job. The less travel you have, the shorter the shaft the more stable you will be. If for no other reason, I use the blocks to help keep the landing pads clean and out of the dirt.
  • The jacks have a limited travel range and if you are too far off level, the system may not even energize. We carry a few wood boards to get closer to side to side level. We have also found that if you use blocks under the jacks to keep them from extending so far, the trailer is more stable.
    Ken
