thomasmnile wrote:
Cummins12V98 wrote:
gpshemi wrote:
06 3500 SRW Megacab w/ 285's / 3.73, towing Cyclone 3612 Toyhualer
Hitch: 3200lbs
Dry: 13,800lbs
CAT Scaled: ~28,000lbs with gear.
Runs good. Tows good. Been through two (unfortunately) emergency maneuver with it. Personally, still wouldn't want a DRW. Just my $0.02.
YMMV for sure and that's what really matters.
What does your TV rear axle weigh?
I just hope for your and others sake you don't blow a TV tire.
Dunno what his rear axle rating is, but I have the same truck ('05 3500 SRW, no big change in '06 that I know of) with 265 70R 17 tires (Load Range E, 3195lbs) on it and the rear axle weight rating is like 6300 lbs. When I had my fifth wheel, I (2450 loaded pin wt) very close to, but within the axle weight rating, and total combined gross weight was 20345 lbs.
The reason I ask is that I know what the tires are rated for and with 28k combined load I suspect he is over the rear tires carrying capacity. He mentioned weights at Cat scales but did not include rear axle weight.
