Derick
Aug 08, 2018Explorer
Y-Guy wrote:
Before you have the ramp built I'd get your setup to some CAT scales to see what your tongue weight is and what it's going to be with the Harley up front. Most of the weight of that Harley will be transferred right to your hitch. Check your specs for your Burb too. Adding anything won't change if you are beyond your ratings, but might make the drive better.
Will do...there are two truck stops within 20 minutes that are on the cat locator map. I'll get it weighed ASAP.
Back to cantilever....could I throw in 200 lbs of sand in the back to help even things out?
About Fifth Wheel Group
