the_bear_II
Nov 25, 2016Explorer
That happened with our 5th wheel after the factory flipped the axles. They forgot to weld a cross brace between the spring shackles. One curb strike knocked the axles out of alignment. They realigned the axles and installed the cross braces and we've never had a problem since.
The pins only have 1/8 inch clearance on my spring setup so I would be able to get about 1/4 inch adjustment by loosening the u bolts and moving the axle. I did have a pin break off on my 4X4 truck once.
About Fifth Wheel Group
