Rocksride's avatar
Rocksride
Rear axle is 3/4 inch further left than front
First trip with my 2016 Jayco FBTS the left rear tire rubbed on inside bottom of left slide. CW looked at and said normal movement. BS . The entire axle is over to the left but leaf springs and brackets are straight. Tires wear fine, it appears that if you jacked trailer and loosened all u bolts u could move axle to the right about 3/8 inch. There is some space between the axle mount plates and u bolts. I just picked it up and moved to my site, as soon as I can I am gonna measure the welded mounts on axle to compare with the front axle to ensure they r the same. Any help with this issue
Tks
Rock
  • Sounds like a typical CW answer. I doubt you can simply slide the axle over, there is a pin in the springs that fits in the axle plates.
