Area13's avatar
Area13
8 years ago
Big Camper-Happijac fronts, Torklifts rear?
I bought my truck used with the happijac setup. It's got the supposed frame mounted Happijac tie downs in the front with the stabilzer bar, not just the ones with the tabs only bolted to the bed. I decided the Happijac bumper mounts on the rear are no bueno fosho, so I sprung for torklifts in the rears. I decided to try it out and not sure if torklift fronts would be better for my situation with a 5k wet camper, hard to tell, nothing to judge it against and only a couple of trips in. Has anyone switched and/or know if I will get a better ride and or stability by switching to torklift fronts, or having these frame mounted happijac front only setup and torklifts in the rear just as good?
Click For Full-Size Image."> Click For Full-Size Image.
