kjenckes wrote:
Th… it might hit my fender on 1 side and exhaust on the other. The torklift bracket sits forward just enough to clear. I'm leaning to front and back torklift because I am nervous about the rear bumper. …on.
For the rear, if you are mounting the Torklift to a receiver hitch, you can rotate the Torklift mount forward or back to get it angled exactly how you need it to sit. I did this on my Ram to keep it as close to the body without hitting, high enough to be mostly above the exhaust and still at a good angle to hold the camper properly.
I rotated it just 8-10 degrees back, clockwise. Don't think it has to be bolted in exactly square to everything, it does not.
This makes it sit closer to the body than if I had mounted it square and level. Closer means higher and more out of the way for any off-roading encounters with rocks, and also less visible hanging out under the truck… cleaner lines.
Mounting it square-up would have put the bracket exactly in the exhaust stream, much lower.
Is hard to see, but the bracket is just barely missing the body, I gave just enough room for it to flex up and not touch.
This is with the bracket clamped on in a mock trial all squared up as most will mount it, directly in the exhaust and several inches lower.
