larryn
Jul 06, 2014Explorer
rear axle weight
If I am 200# over on my rawr is this a big deal truck steers fine ,rides well, does not bottom out rear axel rubber bumper ,and stops well.Please no lectures just need good opinions, thanks in advance...
Dayle1 wrote:larryn wrote:
Rawr 4200 #/load 4360 , gvwr=16000#/load=14860, max trailer#=9700/load=9000, rear tire rating=5340/load=4360#. Truck is a 2009 1500 maxtow 6L. If I go to e rated tires will I need higher rated rims , stock 17 in. rims.
Seems like you already have higher rated tires than the rear GAWR with about 1000 lbs excess capacity already, why change tires or wheels? Try the setup as is, then decide if you need air bags, etc. to level the load.
