chevyman2
Mar 16, 2015Explorer
at an angle does help just a bit. What helps more is closer to the axles. The axles do still hold most of the weight, the also give most of the shake. If you can move them closer in, you will get less shake. You will NEVER never completely eliminate shake. (Well anything short of permanent setup on piers).
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
