laknox
Jan 28, 2020Nomad
BillB3857 wrote:
We bought a used 5th wheel that had 3 cameras. One rear view mounted on the outside above the full width rear window and the other two are side view mounted about shoulder high forward of the cross-over storage doors. Wiring for the rear camera is run across the roof being held down with Dicor, then enters the corner molding and hides behind the vinyl strip. From there, it follows the frame to the front where it goes into the front storage compartment. The other two cameras are mounted far enough forward that the wires go directly into the front storage compartment. From there, they are bundled and zip tied to the 7-way cable. On the truck, I drilled through the side of the bed near the 7-way connector and mounted three fittings that would mate with the cables. Inside the truck, i mounted a small 5" display and a switch that would allow me to select any of the three cameras. One thing to watch out for is that the camera actually sends a reversed image so that what you see is the same as you would see in the rear view mirror. Otherwise, it really messes up your brain.
Had a friend who did this on his Newmar Kountry Aire. Had a 7" or 10" dedicated monitor for them in the cab of his Sport Chassis Freightliner. Could switch between 1, 2 or 3-way split or isolate any one cam. Side cams were in really nice little aero pods and painted to match; almost unnoticeable. All were hardwired into a single plug that plugged into a socket on his truck.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
