- Jimf1234ExplorerIs it a fuse or the breaker for the hydraulic pump? Does it fix it itself after a minute? This was also happening on my 365 so I added another breaker to split the load and haven't had any other issues. Going from memory I think it was supposed to have a 50amp breaker but only came with a 30amp
- vampirefishExplorerMy 371REBH Sandpiper's slide out fuse blew and they had to replace the control panel on it (something like that). Have had nothing but problems with this unit :(
- filrupmarkExplorerSince its happening in two separate systems with one common part. I would check the water in your batteries first. Low voltage causes high amperage which in turn blows fuses. You also should do some lubrication maintenance to the slides and leveling system.
- garyp4951Explorer IIII would post this in the Tech Issues section.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
