- laknoxNomad
pinesman wrote:
For those who have used Heng's, or something similar, did you paint any of the metal trim also? I asked over on the tech section but gbopp was the only one who answered. Just looking for the best seal between the rubber and metal trim. I don't know whether to tape the trim or below the trim.
I think I'd put the coating up on the trim a bit, then Eternabond over the top of =that=. :B
Lyle - pinesmanExplorerFor those who have used Heng's, or something similar, did you paint any of the metal trim also? I asked over on the tech section but gbopp was the only one who answered. Just looking for the best seal between the rubber and metal trim. I don't know whether to tape the trim or below the trim.
- GulfcoastExplorerIs everyone that has used it, still satisfied with the product?
- 2012ColemanExplorer II
donewithtrucking wrote:
That's a relief - because if you "foof" has weak spots, then your in big trouble...
Sorry i mispeled roof. Weak spots, meaning there is some rot on roof top along top by outer edge. Not going to invest money in removing roof, just trying to get another 5 years. Hung coating seems like the best deal. - cummins2014Explorer
gbopp wrote:
Heng's Rubber Roof Coating Works for me. Easy to apply, no primer needed.
Clean your roof well before applying.
I used 2 1/2 gallons to coat 30' of roof.
Have you had any long term results with this product to report . I am interested as to the longevity of this brand . - Cummins12V98Explorer III
Rot in the Rubber Roof??? Or supporting wood structure??? - donewithtruckinExplorerSorry i mispeled roof. Weak spots, meaning there is some rot on roof top along top by outer edge. Not going to invest money in removing roof, just trying to get another 5 years. Hung coating seems like the best deal.
- agesilausExplorer III
Ditto on the Hengs. Went on easy and left a thick white coat. - valhalla360NavigatorWhat do you mean by "weak spots"?
If there is a leak causing the underlying plywood to rot, slapping a coating on top, is unlikely to fix it. - gboppExplorerHeng's Rubber Roof Coating Works for me. Easy to apply, no primer needed.
About Fifth Wheel Group
