bpounds
Jun 16, 2014Nomad
With these Reese hitches, the main reason they will be difficult to open is because the pin is pushing rearward against the jaws. The design of the jaws is such that they won't open with any pressure on them. You might have to use the truck in reverse gear to put rearward force on the pin, while someone else does the release handle operation.
Raising the pinbox off the hitch head allows it to swivel a little bit, which can be effective in relieving contact between the jaws and pin, but that is not supposed to be necessary, and if you can't do that due to the lube plate thickness, your only option may be as I suggested above. You will have to decide whether that full face lube plate is worth the hassle of a 2 person disconnect.
Personally, I would be worried if there was zero clearance between the bottom side of the jaws and the bottom hub on the pin. Too much chance that the jaws won't close properly in the groove. I can think of a couple of ways to fix that, but not simple to do. Removing the lube plate is the only simple thing.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
