Which is the real case???
firepoggy wrote:
I do not wish to have the rails in the bed anymore.
Or
firepoggy wrote:
If you know of any hitches that fit in the goosneck hole
Do you need a gooseneck setup for other towing purposes? If not get a fifth wheel hitch with an 'under bed mounting system' (UBS) and unlock the Revolution.
If you need to also tow gooseneck trailers, but can live with a little more effort making the changeover, then call B&W and ask about adding 4 corner bolts on the original Companion hitch. In the past, they have OK'd using the Companion with the Revolution provided the extra bolts are added to keep the Companion from twisting.
Hope this helps.
