I guess I am going to be the lone critic of the Revolution hitch. Logic will tell you that you now have a hybrid between a fifth wheel set up and a travel trailer set up, therefore you will compromise some stability in crosswinds.
I bought a Rockwood fifth wheel with Revolution hitch about a year ago. Owned a Chev long box and towed in the locked out position. Very stable. Bought a F250 short box with six ft nine in bed. Used the hitch with the universal wedge provided in the Revolution mode and found that I was much more affected by crosswinds to the point where it really bothered me. My brother who followed me in his motorhome in a heavy cross wind said that he did not notice any sway but I could sure feel it in the steering. Ended up buying a manual slider hitch and it tows much nicer. Going forward I can do a 180 degree turn with my steering wheel as tight as possible and the trailer still does not touch the cab. I have not yet had to pull the lever on the hitch backing up although I know I will have to be vigilant. So for me, I much prefer the slider hitch. One thing to keep in mind however is that the F250 short bed is longer than the Dodge and therefore what may work well for me may not for you.
So I'm going to sum up the pros and cons of the Revolution mode according to my experience
Pros
Can turn your trailer ninety degrees to truck without hitting.
Can use a simple economical light weight hitch in truck
Much better use of truck bed
Cons
There is definitely less stability
It is definitely more difficult to hitch up and sometimes to unhitch
It can be noisy when it turns
It needs to be taken apart, cleaned and greased according to the manual annually. I have done this prior to deciding to go with the slider hitch and lock out mode. Not an easy job and means you have to buy some large sockets or pay a stealer to do this.
Lastly, someone else can't tow your trailer in a pinch unless they lock out the pin box or have an identical hitch on their truck.
Hope this helps. I have experience with the trailer in either node and prefer the slider hitch.
