We just got a 2017 Jayco Eagle HT 28.5 with a reese revolution. I have a Pullrite Super 5th hitch. does anone know if i have to make modifications or are they compatible?
They will work together IF you lock out the Revolution pin. There should be two bolts that install through the pivot plate on the Revolution pin box.That makes it work just like a regular pin box.
