roman_traveler
Mar 31, 2014Explorer
I use the same hitch. It seems like it has to be used a few times to break in. I had the same problem, but now it's smooth as silk. It is very sensitive when the jaw is open. Pull away very slowly. Sometimes the slightest jolt will close it around the pin. Also you need a 12 inch lube plate, not the standard 10 inch. Good luck.
RT
RT
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
