Reelin' wrote:
I have a Reese signature series hitch in '03 Ram. I just bought an '18 Ram and would like to use the same hitch. Reese doesn't make an underbed setup for the new models. It doesn't look like the Reese adapter will accomodate the signature/elite model.
Anyone have a solution?
Yes, a Reese 30154 picture frame adapter, if you have the OEM fifth wheel prep. I have a 2014 Ram 3500 with the OEM fifth wheel prep, and the reese picture frame adapter, and a rail mount Reese signature 18K fifth wheel hitch attached to it. The Reese adapter is around $375.00 .
I have to assume your reese hitch was attached to bed rails in your 03 ??. If so then the reese frame adapter will work.
