MFL
May 23, 2015Nomad II
Baja Man wrote:
actualyy instructons do not say to remove wheels, only to jack up rear axle and use jack stands.
Question....why do the brackets only connect to one hole on each end of rail? Each end of rail has two bolts but only one connects to frame bracket?
That means there are only four bolts connect to rails and six connect only to sheet metal of bed. Correct? Doesnt seem right.
Yep, that is how it works, with the universal rails, 4 bolts, rails to frame. Be sure to use proper spacers on the bed sheet metal, as they add strength, and keep the bed kink free.
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
