Baja_Man
May 23, 2015Explorer
do those spacers go on top or bottom?
On top of bed.....I'm assuming bolt heads on top of rails need a spacer if they are atop a depression and no spacer if they are on a hill, correct?
Under bed..... if that same bolt on top of a depression (top of bed) will be a hill under bed and not need a spacer. If bolt on top is atop a hill, the under bed it will be in a depression and a spacer would be needed, correct?
What do you do if the hole ends up between a hill and depression on top or underneath? If you move rail to one side to avoid this, rails are no longer centered between bed wheel wells.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
