laknox
Aug 23, 2013Nomad
Kimbrey wrote:
We just bought an Arctic Fox 29-5T which I'll pick up in a couple of weeks when I rotate home from my work in Alaska.
New to the 5th wheel game so I'm trying to have everything set up and ready to go before I get home. It's fairly tough researching via a slow internet sat connection here on the boat so I'm looking for some advice.
I have a 2013 Chevy 3500HD Duramax crew cab long bed DRW. Beside the new 5th wheel I also have a Eagle Cap 950 camper that I will use when towing my boat to various places to fish so I want a 5th wheel hitch that is fairly easy to remove.
Emailing with the dealer I told him I thought the B & W turnover ball under bed mount with the B & W Companion hitch would be good. He said yes and gave me a decent price for the install but he said I should consider Reese's under bed mount and Elite hitch. From what I've read both sound like a decent system. He said the price would be close to the same.
I want to have a clear bed when the hitch is off the truck so the camper won't be resting on anything when I'm packing it around. When using the camper I will have a heavy rubber bed mat in the bed.
Sooooo do the pucks from the Reese system leave much of a protrusion in the bed that could do damage to the camper? I can't tell by the pictures I've seen. Or are the pucks flush so I won't have to worry about it?
Same questions for the B & W system
Any opinions of which way I should go?
Thanks,
Kim
Kim, I have both the B&W Turnover Ball and the Companion FW hitch. I couldn't be happier with them AND with B&W as a company. You need something, like new hold-down u-bolts (which do go bad on occasion)? Call them, give 'em your serial number and address, and you'll have a new set overnight. Have a question? They've been willing and eager to promptly answer questions the few times I've called or emailed. I installed my own base and the biggest issue I had was getting up the never to actually cut a 4" hole in the middle of my bed! :-) Since I do also use a gooseneck on occasion, I installed the safety chain loops, but they certainly aren't required if you never tow a GN.
Lyle
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
