- Old-BiscuitExplorer IIIWhat BRAND & MODEL???
NUWA HitchHiker II LS....they used Dometic but you stated Norcold????
With Correct Brand and the Model it makes for better specific info...OK?
Thermistors are replaceable
Some require cutting/spicing new tips, some unplug/plug new in, some can be OEM and run wires or aftermarket.
BUT depends on BRAND/MODEL. - SidecarFlipExplorer IIIReplace it. In fact, get an adjustable one.
- Gray_FoxExplorerThanks That frig. came with the unit. Can the Thermistor be replaced or do I need a new Frig???
- ksg5000Explorer II
Old-Biscuit wrote:
Couple of things come to mind......
What temp setting are you using?
Thermistor......
Is it attached to FIN?
YES.....
Then it probably has failed.
x2. when Thermistor goes toes up the fridge reverts to 24/7 max cold mode. - Old-BiscuitExplorer IIICouple of things come to mind......
Thermistor......
YES.....
And what are you doing with a Norcold in a NUWA HitchHiker II (Dometic)????
About Fifth Wheel Group
