- beawrestlerExplorerDometic 12 RM1350MBSX- SERIAL NUMBER IS-32987124
- turbopilot51ExplorerI had two issues with my Dometic side by side. First the door would unlock itself driving down the road. Second the middle flapper was not closing all the time. Both items were fixed under warranty by the dealer. PM me if you want details.
- the_bear_IIExplorerIf it's under warranty take it in.
Let the experts(?)work on it so you'll have a paper trail in case it can't be fixed. If you try to fix it you may void the warranty. - missourijanExplorerAny size or model of Dometic frig should have a lock on it, does it not work? On the big 4 door Dometic 1350 they have had issues with the seals not holding cold air in or sealing well (magnets not big enough). If you call Dometic directly they may offer to send you new seals and middle flapper if you have the that model.
- HappyKayakersExplorer III
Old-Biscuit wrote:
Which MODEL of Dometic Fridge so you have?
Yes indeed, the model of the frig would help far more than the type/model of your RV. - Old-BiscuitExplorer IIIWhich MODEL of Dometic Fridge so you have?
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
