Old-Biscuit
Jul 18, 2017Explorer III
Freezer section getting down to 5*F or lower and food compartment NOT cooling down is sign of obstruction/blockage in tubing between the 2 evap coils
What 'fault codes' are you getting?
Are the 'fans' in outside compartment running?
Have you been operating rig off-level' when stationary ----even during short roadside stops? (2 cooling units????)
Have you tested door seals for leakage..place dollar bill across seals and close door then pull bill out......S/B strong resistance ----check several places top/bottom/sides. Leaking seals ----warm air in ---lack of cooling
Simple test........
Unplug thermistor (at light assembly)
Turn temp setting to MAX
Run fridge overnight then check freezer/food compartment temps
Freezer S/B 5*F or lower (lower the better)
Food compartment S/B 38*F or lower unless obstructed/blocked
If temps do go low then replace thermistor'
If freezer does but food compartment doesn't.......bad cooling unit
Simple test........
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
