bpounds
Aug 08, 2016Nomad
slarsen wrote:
I just looked up in the owners manual, the trailer tow battery charge circuit is fused at 25 AMPS. That seems like sufficient power, if the voltage doesn't drop too much all the way back to the breaker box.
When I'm plugged into 120V at a campground, I should be able to top off the battery overnight. I think. If the regular battery doesn't interfere with charging my refrigerator battery. Or vice-versa. This 12V to 120V ends up being surprisingly complicated.
Guess when I travel, I'd better take along a 120V battery charger, just in case?
Maybe I misunderstood. It now sounds like you have a separate battery that you dedicate just to the little fridge? Why not connect it all together and let it charge together?
My truck does a good job of charging the battery bank while on the road. I can't speak for others though.
About Fifth Wheel Group
