1st off is fridge being operated LEVEL?
2nd thing is that Model (RM2862) has 'adjustable temp setting' (1-5) so thermistor should be in OEM position as that is where thermostat is calibrated for the temp setting range
**Fridges that use the 'Auto Temp Control' (no temp setting) you can move thermistor UP/DOWN for minor affect on overall temps
What temp is Freezer holding?
What temp is Food Compartment holding?
12VDC is needed for Controls, Display Panel and fridge functions on Electric/Propane
One simple test is to remove thermostat/clip from fin and let it dangle so it is just hanging
No temp sensing of FIN the thermostat will run fridge continuously
**Freezer/Food Compartment should get VERY Cold after 12hrs of running w/o thermistor sensing
Freezer getting COLD (10*F or lower) and food compartment NOT could be:
*Off level operation
*Thermistor
*Gas pressure/dirty burner
*Circuit Board
**CLOGGED Cooling Unit (between freezer coil and food compartment coil
SO
Answer the questions about temps
Try 12 hr run W/O thermistor
Post back
