RTBabich
Oct 27, 2014Explorer
Y-Guy wrote:
You need to vent the top, Hydrogen will not vent downward since Hydrogen is lighter than air. Introducing Hydrogen into your living area is a bad idea.
Play with the scale some, you're really not going to save that much weight, if you are over capacity you need to consider other options IMHO.
I was thinking to not actually mount the box in the floor, but under it. The box would not be sealed with lots of holes for venting, solid in front for rock damage protection. An access hole in the floor would be edged with metal, sealed with a gasket and screwed down. This is similar to older class-Cs with the battery under the floor that have a flip up panel for access in the steps.
I think the tongue weight is just under max. My calculations show about 100lbs off the tongue.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
