otrfun
Oct 28, 2014Explorer II
RTBabich wrote:Assuming everything remains *static*, 750 lbs. is 13-14% of 5600 lbs. That's within the typically recommended 10-15% tolerance for tongue weight.
The TV is a 2003 Expedition, 5.4L, 2WD, 3.73L, Class V factory tow package, 8900lb trailer, 880lb tongue, Equalizer 1K/10K hitch.
The trailer is a WW FB2100 5600lb, 9K max, 815lb tongue.
It will be lightly loaded for short camping trips.
I would think a 750lb tongue weight would be enough to keep sway under control.
To be prepared for *dynamic* situations, have you run the numbers with your waste/water tanks and fuel/propane tanks empty and full? With potentially unexpected toys/gear behind the TT's axles?
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
