1L243
Oct 28, 2014Explorer II
Tongue weight should be between 10 and 15% of gross trailer weight. Your fine where you are now without moving the batteries. If you reduce the tongue weight you may make your problems worse. If your having sway issues you can add anti sway devices. If the TV is not handling the weight you can address that too with air bags.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
