RTBabich
Nov 05, 2014Explorer
otrfun wrote:
... Curious, what is the current length and gauge of cable from your converter to your batteries? Will the length increase or decrease by moving the batteries? FWIW, cable size (gauge) is typically undersized (restrictive) on most OEM installations. If you’re going to rerun the cable I would consider using a larger gauge cable. This could reduce electrical losses and decrease charge times.
The converter is an Inteli-Power 9100 40A. The output has 2 wires. One wire is 8ga which goes to a fuse block with six 12ga leads from it. The other is 10ga going to the batteries about 10ft long.
About Fifth Wheel Group
