Bandaid
Apr 01, 2015Explorer
You can go to your local Fastenal store and purchase Stainless Carriage bolts, nuts, washers and lock washers. Before you put the washers and nuts on the bottom side, squeeze some adhesive caulk around the bolt threads. Then tighten the nuts down.
You could also put a little caulk under the carriage bolt flange to seal it to the bed liner.
Bandaid
Bandaid
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
