Cougarnewbie
Nov 14, 2016Explorer
This problem was discovered mid summer. We took down the plastic around the king pin and found that the "plate" that runs front to rear that the side wall rests on was ripped. The plate is a piece of bar stock welded to the box frame that the side wall rests on with 3 inch screws shot up into the wood of the side wall. A local welder came and welded and stiffened the plate. The frame members that we could see looked pristine, but we could not see the front of the beams. After the plate was welded the problem returned immediately, leading me to think something else is broken to allow the flex.
There are pictures on here from that repair. I will try to post them here.
Larry, your idea sounds very promising. Thanks
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
