NEnativeExplorerMay 01, 2018removing a pinboxCan anyone tell me the proper way to remove and then reinstall a factory pinbox from a fiver? I want to remove it so I can weld a receiver hitch on it.
RCMAN46ExplorerMay 04, 2018Try rigging up a bolt fishing wire such as this from some bailing wire. Or you could tack weld the wire on the end of the bolt.Nut would be on the outside but that should not be a problem.Bolt fish wire
Related ContentStaple RemovalPinbox moves?Morryde pinboxEasy way to remove slide topper?Reese Sidewinder Pinbox
