cummins2014
Feb 27, 2014Explorer
Leland2 wrote:soos wrote:
We unbolt it and leave the whole hitch on the pinbox when we need to.
sue
Can you (or anyone) write about how this is done?
I removed the pins holding the TS3 to my truck bed, and raised the front of my 5ver. The TS3 started raising off center and seem to get stuck in one or more corners. I couldn't hold the switches (raising the front of my 5ver) and straighten the TS3 at the same time so gave up on it.
It really didn't look like the TS3 was going to lift properly out of the truck bed. Also, it looked like there would be some difficulty lining my truck up to get the TS3 to lock in position.
When lifting mine out I just kick it down on one corner to break it loose if it binds a bit, It is no big deal. Going back in if a couple corners are lined up it will settle in with a little guidance
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
