oldretiredafguy's avatar
Nov 06, 2014
Removing Electric Drain Valves
We've been having problems with our electric drain valve switches for most of this year. Have ordered and received incorrect switch boxes twice from the OEM. Tired of this and want to replace them with manual valves. Any suggestions as to using cables vs rods? Easy to do, or should we use a technician/dealer? Any words of wisdom will be greatly appreciated.
Thanks
  • Hi Mike, I would have a RV Tech take a look at your problem, It is strange they sent you the wrong switch twice. You could have a simple on-off switch installed, would be a LOT less trouble than switching over I would think.
    Good luck on it.
