jo1991's avatar
jo1991
removing storage pods on roof...fixing holes???
hi everyone,
we are removing the old storage pods on the roof, which will leave 18 holes to seal. would you butyl the hole, put in screws and then seal, or leave screws out, butyl an seal, or just use the roof sealer? thanks, lisa
  • Gheesh! Everyone is still going on about Eternabond and not warning to NOT USE SILICONE with it. You also can not use silicone on a RUBBER ROOF - first things first... what kind of roof is it?
    From the era when those pods were popular, your roof could be nearly anything.
  • I would put the screws back in and then seal as mentioned above
  • ford truck guy wrote:
    I suggest you fill the holes with sealant and then use Eternobond tape over all the holes . .
    +1...
    Tim
  • I suggest you fill the holes with sealant and then use Eternobond tape over all the holes . .
