DutchmenSport wrote:
Well, if it were mine, I'd probably cut the rubber back a little. I'm make sure the inside of the roof was good and dry.  I'd make sure the rest of the ceiling is dry, the walls are OK, and nothing is damaged by water intrusion. I'd then get a couple cans of Foam Stuff and pump as much as I could inside that hole, which will adhere the ceiling to the foamy Stuff also, as well as the underside of the roof. But it would seal it all.
Then I'd lay a sheet of tin a bit bigger than the hole between the roof and the rubber with some Liquid Nails between to seal it down. Then lay the rubber back over the tin sheet and then use Eternabond tap to seal the seams of the rubber, and last, logs of RV caulking on top of that. Then ... never step on that spot again. It will last forever.
Edit?
I'm assuming the hole went clear through to the inside, after re-reading your post?  If the hole went all the way through the inside ceiling, do the same thing on the inside. Before pumping in the Foamy Stuff, simply find a decorative ceiling "pretty", like a medallion used for lights or ceiling fans. Anything that looks pretty. You can get a nice decorative covering and simply glue it to the ceiling over the hole inside. You may need to use a few fine screws or a staple gun to hold it in place. Liquid Nails is great for stuff like this.
Then when the glue dries, or Liquid Nails dries the covering over the hole, do the outside of the roof and "pump the stuff" full!
Thank you very much 4 the advice.
No it is just the roof. the inside ceiling looks great.
so your saying a thin sheet of tin between the roof and the rubber. That may be possible. I was planning on just putting something directly on the finished roof and seal and screwing it down and then caulking it all up.
thank you again for the advice. you a big help.
