CloudDriver
Oct 11, 2013Explorer
OK, I have not done this, but I recall the following suggestion from a past post.
Drill a small hole in the side of the valve body on the opposite side from the handle. Insert a steel rod or something similar into the hole and push the valve open. If the rod is a close fit in the hole, there should be minimal leakage.
Good luck!
Good luck!
About Fifth Wheel Group
