- dpgllgExplorerI am in the process of replacing most of the carpet in our 5th wheel. In during research I think you will discover that laminate is not a good choice as it swells with moisture. I can say that is true as the laminate in our bedroom got wet and swelled / buckled.
Most advise using the vinyl plank flooring as it is moisture resistant. Also to use the click lock method over the glue strips.
I am using this product from Home Depot.
Sawcut Arizona
Hope this helps!
Dave - BarneySNomadSearch results on laminate,replace,carpet over the past year. I think this will help you a bit. :)
Barney
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
