-lenny-'s avatar
-lenny-
Replace suburban SW12DE with Atwood On Demand?
Hello all,
We are finding the water heater in our new coach leaves a bit to be desired. We prefer longer showers, and the recovery rate does not permit this. Our old trailer if you had both power and gas heaters on, provided an ample source of hot water and fast recovery when you did run out. Perhaps I am missing something here, but I have the gas heater on, as well as the electric and even a relatively quick shower exhausts the hot water supply. So we are considering replacing the hot water tank with an Atwood on demand heater. Interested to hear pros and cons, or different ideas all together. Thanks in advance.
We camp almost exclusively in full service sites. Overnight in walmart a few times a year. No boondocking, no kids.
  • Thank you for the replies. I do believe the electric is working, but it seems to have quite poor performance. I will check to make sure I am not getting cold mixed in with the hot, and go from there. I appreciate the feedback regarding the on demand unit, don't want to spend the money if it is a waste.
  • I have only heard negative comments about the Atwood on demand heater.
  • Old Biscuit gave you some very good suggestions - including the fact that a lot of folks have been disappointed with the on-demand systems. Do a search and you will see.
    Good Luck.
  • Are you sure the electric element is heating?
    Suburban uses a 12,000 btu/hr burner (2000 btu larger than Atwood)
    With gas/electric it has the fastest recovery time (10 gallons/hr with gas and an addition 6 gallon/hr with electric)
    Either the electric is NOT working
    OR
    Cold water is mixing with Hot.......bypass valve leaking thru/not closed or outside shower not turned off with hot/cold knobs (just on handle)
    Before replacing unit I would verify that both sources are heating.....and cold water isn't being mixed with hot
    Besides....those on demand leave a lot to be desired in RV use
