shadows4's avatar
shadows4
Explorer III
Apr 21, 2023
Replacement axle question.
Hey guys, I have a question some of you might be able to answer.
I had a bent axle replaced by a local company. The trailer tows fine and braking is good. I had them replace the springs and brakes all around. So the only thing original is the front axle. I thought it looked a little off but told myself it was all in my head.
Got under the trailer today and the new axle is 1/2 inch narrower than the original. You can see it on the drivers side. The curb side is lined up like it should be. Is this going to be a problem down the road? Thanks.
  • As long as the two axles are in alignment with the trailer frame and with each other, a 1/2 inch difference in length won’t matter one bit. This assumes the springs are mounted the same difference apart on both tubes (within an 1/8 or so).
    If you want an expert opinion, call Dexter axle on Monday.
  • Not many replies John, likely due to lack of alignment specialists. I can only offer a few thoughts. Are the hangers possibly bent/damaged, since the original axle was bent? Axles are normally bent upwards, with the peak in the center. If this peak differs front axle to rear axle, that would bother me. I would be happier if the new axle was 1/4 inch short on each end, making the axle bend, more centered. In this case, I'd say it won't matter long term.
    I can't answer your question "will it matter", but if mine, I would search out an actual tech for correct info, to satisfy my perfectionist obsession. :)
    Jerry
  • TenOC wrote:
    shadows4 wrote:
    H
    Diameter or length????
    The axle is 1/2 inch shorter in length.
  • TenOC wrote:
    shadows4 wrote:
    H
    Might want to think about that question;
    First, it is normal for axles to walk side to each as you turn. I would think if you stopped to check while going in straight line both axles should be centered. This would worry me. And I would not be satisfied if I paid for new axle installed and did not match.
  • shadows4 wrote:
    H
